Use this procedure to configure the last listener query interval in seconds for the MLD interface.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Configure the last listener query interval:
    ipv6 mld last-listener-query-interval <0-60>
The following table describes the variables for the ipv6 mld last-listener-query-interval command.
Variable Value
<0–60>
Indicates the last listener query interval in seconds.
